LoadRite Elite Tandem Brake Upgrade??? >
Old 05-03-2020, 11:52 PM
I will start with another set of brakes on the rear axle and see how things go. will go with Kodiac or another set of what came on trailer. Kodiac was an option for this trailer. Looks like a 10" kit.
Lafuerza is offline
Old 05-04-2020, 11:24 AM
Forum Regulator
Sydwayz's Avatar
I would definitely go with EoH brakes and brakes on the second axle; given your tow vehicle.
4700 lbs dry is probably 6700 lbs or more wet and including, gear and trailer. Add in the fact that your SUV is going to be packed and loaded down too, you are likely at or over your GCWR.
In the hills, if that boat wants to push the SUV all over the road, it will. Surge brakes only work when the tow vehicle and trailer are in a straight line. If you are in a curve, start to slide, or jackknife, your boat is going to pass you.
I have personally suffered a tow vehicle loss of brakes when the trailer only had surge brakes. (Rusty GM 2500HD brake line snapped.)
Can you say NO BRAKES?!?! Fortunately, I was only 15 miles from home, it was flat land. Downshifting and emergency brake on the truck got us home. For this reason, electric over hydraulic brakes are fantastic.
Sydwayz is offline
The following 2 users liked this post by Sydwayz:
30outlaw (06-08-2020), Padraig (05-04-2020)
Old 05-04-2020, 11:44 AM
I figured 4700 boat, 40 gallons of fuel around 400, and trailer around 1000lbs. Should be in low 6000lb range for the long trip. Short trips might have more gear since Ibleave all the tubing and skiing stuff in the mountains.
Vehicle usually 2 adults and 3 kids so around 650lbs. GVW is 6600lbs. Curb weight is 4750lbs. Add 300lbs for gear to be conservative and I am at 5700lbs loaded. I think they gives a some headroom on GVW.
Let me know if I am calculating it right. Definitely getting brakes on 2nd axle and am figuring out EOH for added level of safety.
I have Cyber Truck on order so wont have to worry about most of this later. In the meantime better safe than sorry.
Lafuerza is offline
Old 05-13-2020, 08:47 AM
For anyone that has made the conversion from surge breaker to electric over hydraulic, how hard was the install? I am not super mechanical, but can manage basic stuff. Looking at the kits from Etrailer they do not seem to bad, but I do not know anyone who has done this.
DESIGNdummy is offline
Old 05-13-2020, 09:11 AM
I did it on my myco and it’s real easy. The brake line from your surge master cylinder connects to your new electric master cylinder there is a battery backup and a control unit. They all plug in with weather pack connectors. Youll need to weld up the Tounge of the trailer to get rid of it sliding back and forth.
flat rate is online now
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
