29 fountain with Chevy 1500
Old 06-18-2020, 08:20 AM
Originally Posted by PA.WOODCHUCK View Post
If the boat ramp is steep your could always go 4x4 mode, less chance of boating pulling truck down ramp?
Our ramp is always slimy so I put it in 4x4 every time.
I am actually starting to think about taking my truck to pick it up at the Ozarks (3-4 hour drive) The father in laws 2500 gasser is rated for 1000 lbs more than mine. My truck is just a little more comfortable to sit in for long periods.
DallasBAJA is offline
Old 06-18-2020, 09:47 AM
I don't see where you should have any issues with that package as long as the trailer has brakes and you have the GM built in brake controller. Use the 4WD for launching and pulling out of the water. MY '17 GMC has the towing package and I have towed a couple of different 33 & 35 boats with a tri axle trailer around town with no issues.
Helmwurst is offline
Old 06-18-2020, 10:00 AM
Forum Regulator
Sydwayz's Avatar
My only suggestion would be to upgrade the trailer to EoH brakes if it doesn't have them already.
Why? Because EoH brakes work in reverse. Surge brakes do not.
While I am confident that your truck is plenty for the load. There is always that freak moment that it just doesn't have enough grip on the slimy ramp you mention. When you put it into 4x4, it should lock the front hubs in, and when you use your emergency/parking brake, you now are locking all four wheels. But in the past on various ramps, I've had the weight of the boat dragging all for locked wheels down a slimy/wet ramp.
EoH brakes will keep that from happening adding additional braking axles under all the weight that's dragging you to the wet stuff.
Sydwayz is offline
The following 2 users liked this post by Sydwayz:
30outlaw (06-21-2021), Padraig (10-11-2020)
Old 06-18-2020, 10:08 AM
I am trying to get details on the trailer. The boat does not have one with it, but found one up the road from the boat. Hoping it has some decent options on it. Should be getting some pictures and info on it today. If it does have electric brakes I will have to purchase a brake controller as mine does not have one that I can tell. Assuming the trailer is in decent shape I will be upgrading parts on it over the boat for the first little bit I am sure.
Old 06-30-2020, 04:50 PM
I've been towing things the size of your Fountain with a modern 1/2 ton for several years. For short distances it works just fine. I put E load rated tires and airbags in them and it helped a lot. Now that I've decided to go long distances for vacations etc I got a diesel 2500.
87MirageIntruder is offline
Old 06-30-2020, 05:18 PM
F-2 Speedy's Avatar
Received 1,407 Likes on 654 Posts
Originally Posted by Baja Rooster View Post
I have the same truck and tow my 272 Islander just fine. If you’re cris crossing the state something more HD would be much more comfortable but for what you’re talking about a Jeep Wrangler would nearly be adequate.
That 29 Fountain is no bigger than your 27' Baja.........
F-2 Speedy is offline
The following 2 users liked this post by F-2 Speedy:
30outlaw (06-21-2021), CaRoCoN (06-30-2020)
Old 06-30-2020, 05:43 PM
you take that back! :P
length wise it should be, but going to be a little heavier and a triple axle trailer instead of a tandem.. I’ll only be towing it to the boat ramp and back and the 1-2 times a year to LOTO and back if that.
Old 10-07-2020, 12:54 PM
EoH brakes? Electric?
Barnacle Bill is offline
Old 10-07-2020, 01:03 PM
electric over hydraulic.
Stuckonstupid is offline
Old 10-27-2020, 10:16 AM
I always use high performance brake pads and better tires on my tow vehicles, it makes a huge difference. I typically run an LT or E rated BFG All Terrain as I have had to tow in snow and ice as well. The heavier side wall really helps with stability in strong side winds. I also added an Eaton Tru-Trac posi, I don't need 4wd with that getting up ramps. I was towing my velocity 280 with my 5.3 Suburban and was doing about 65 and came around a bend with a steep drop with a stop light at the bottom. The brake line on the trailer blew and the Suburban stopped with no problem at all. Now every vehicle I own has Powerstop brake pads on them. I have the tow package on my 03 Suburban and have towed my boat all over the state with no trouble at all. I have over 800lbs of tongue weight and it barely touches the springs on the Suburban. I have even checked the trans temp after towing up and down hills and it was only 195 degrees in the summer. I should also note that I have added a cold air intake, headers, tune and at 150,000 miles I did have the trans rebuilt from a guy that does racing transmissions. It now has 360,000 miles and the drive train is still like new.
ThisIsLivin is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information -
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
