Trailer Components Recomendations
I just completed entirely rebuilding my trailer with new axles, brakes, springs, etc. the only thing I used that was original was the side rails. I agree with Dunnitagain springs are the way to go. Like stated take the time to plan it out with the correct weight springs and it will ride great. I suggest Kodiak stainless disks and Hydrastar EOH master cylinder.
You Never have any issues warping those stainless rotors do you? I want to get away from everything that will rust, I'm using stainless everything I can but stainless rotors I just can't get my head around. I've been working with stainless for a long time and it warps like a mother when it heats up so stainless discs sounds like a nightmare to me. I was going to go with stainless calipers, etc, but not rotors.
My stainless rotors are 3 or 4 years old now. Still almost like new and are not warped at all.
tbev (12-20-2020)
I have had them both, I prefer the radials. Bias ply are okay but the radials are smoother and don't develop flat spots from sitting. Whatever you get make sure to get a tire that is weight rated for more than you pull, you will also want to watch your tire pressure and speed rating. There is nothing worse than saving a couple of bucks on a cheaper tire, then finding out it cost you 5 times as much when you loose a tire, delay your trip, or worse damage your trailer or boat.
1Zoom (12-21-2020)
to me one of the biggest items people cheap out on is tires.. my myco had lt tires on it, it was painful to watch the sidewalls in a turn wondering if it was going to pop off the rim. once i switched to 14 plys the world was a better place. towing, turning, no more jolts on expansion joints, no wobbling.. very much worth the extra money
tbev (12-22-2020)
I just switched from bias to radials this last year and found the radials were much more squishy, but filled up the air pressure to the upper end of the recommended range and things smoothed out a great deal. The extra air pressure also helps keep the tire from twisting in a knot on tight turns. I don’t miss the bias plies needing a few miles to round out the flat spots.
tbev (12-22-2020)
Over the summer , I towed from south Florida to lake powell , then to ATL and then back to Fl. I have all stainless Kodiak brakes , Goodyear endurance tires, airtight hubs , and torsion axles. Not a big boat. A Donzi 22 classic. My trailer is 4 years old. I didn’t have to add any grease to the hubs or air to the tires. 5400 miles round trip and not one problem. I am sure my trailer has been dunked in saltwater well over 100 times. I did add an EOH system before I went out west. Aluminum and Stainless Steel will serve you well. And good tires with the right air pressure.
