Best Way to Bleed Surge Brakes
I had purchased a pressurized brake bleed kit from Speedi-Bleed to do my vehicles. I had just replaced the entire brake system on my 03 Suburban and wasn't going to speed 3 days yelling up and down to my wife. Needless to say this thing is awesome. My trailer is 12 years old and other than repack bearings I hadn't touched the brakes. So I made an adapter for the master cylinder and used the pressurized bleeding system to get the job done in under an hour. Here is a picture of my adapter.
The following 6 users liked this post by ThisIsLivin:
AllDodge (03-06-2023), CheckmateScarab (03-06-2023), Griff (03-06-2023), SB (03-06-2023), sonicss42 (03-11-2023), Twin O/B Sonic (03-14-2023)
A vacuum system would work as well. I spent a few hours trynig to bleed the brakes on my 2010 avalanche. after replacing both rear calipers. Just would never bleed out right and pedal was always spongy. So i hooked a vac up to the master cyl and BAM back to normal
-Wally
-Wally
Good job.
I have a pressure system too. Definitely the way to go, even over vac systems, for most brakes . clutches, and etc.
I make the adapters the same you did for things I don't have, or they don't sell, an adapter for. Buy another cap and put a fitting in it.
Air press bleeding works well, just don't let the master cyl run out of fluid.
one assumes you only use a few psi of air pressure?
Baja 252 Islander
Baja 252 Islander
The following 2 users liked this post by bajaman:
smashm (05-18-2023), Twin O/B Sonic (03-14-2023)
I use 30 psi to the regulator on the bleeder and 15psi on the master cylinder. I have tried suction style bleeders and they are garbage compared to the Speedi-Bleed. The problem with the suction style is they pull air around the threads of the bleeder. Pressure bleeding is sealed and no air bubbles. I use the suction bleeder to suck the oil out of my lawnmower now.
ThisIsLivin (03-17-2023)
I think I see another project in my future.....
Thanks. Brad.
(937)545-8991
The following 2 users liked this post by SB:
Padraig (03-20-2023), ThisIsLivin (03-21-2023)
