-   Trucks, Trailers and Transportation (https://www.offshoreonly.com/forums/trucks-trailers-transportation-159/)
-   -   Trailer bunk brackets (https://www.offshoreonly.com/forums/trucks-trailers-transportation/379204-trailer-bunk-brackets.html)
nygman11 05-10-2023 07:09 AM
Has any one ever used these to mount the bunks on a trailer?
CE Smith Double U-Bolt Bolster and Swivel Bracket Assemblies - Galvanized - 16-1/4"
Perlmudder 05-10-2023 07:16 AM
So I used these to change over my Glastron Carlson CVX 16 trailer from rollers to bunks. You definitely need to use square bolts to mount them to the trailer. It took a while to get them set up properly. I saw online people had them mounted perpendicular to the trailer frame, when I tried to do that they always shifted. I finally mounted them on an angel pointing out and they now seem to work well.
nygman11 05-10-2023 07:43 AM
Is there anything better to use?
Perlmudder 05-10-2023 08:15 AM
Maybe something fabricated from a custom shop? I think for their price point they are alright, but definitely nothing special. I thought about having them brackets welded to the trailer, but I guess you cannot weld galvanized to regular steel?
cheech 05-10-2023 11:47 AM
Done all the time.
