Any Golf cart gurus on here?
Me and my good friend did some trading on some boat work and stuff and an engine I had for his boat on a golf cart.
It’s lifted with 23in tires on it. It’s a ez go with the forward and reverse switch on the dash. ( not between legs) https://cimg4.ibsrv.net/gimg/www.off...44a7fb503.jpeg Unsure of year of it. Brand new batteries. 25-35 minutes of crusin aeound ( not fast ) the control box I guess it’s called with the towable switch on it under the passenger seat is getting hot to the touch and shutting it down. Let it sit for a little while it’s fine again for a little bit. Is there something I need to do to help keep it cool? Or is there an upgrade? |
87CigCafe,
I'm not a guru of any sort, but.... Can you gain access to the control box? Maybe pinpoint what component is actually getting hot? Thanks. Brad. |
Are you 100 % sure that the correct voltage batteries were installed on this unit ? I have worked on some that run on 36 volts, and some that are 48 volt systems.
Do you have access to a copy of the owners manual for it ? If so, that should tell you what were originally installed in it. Have you asked the previous owner if he was aware of that issue when he owned it ? I have found that a lot of these carts have been butchered along the way, so you will need to verify a lot of stuff to try and figure out what configuration you now own. |
| All times are GMT -5. The time now is 10:01 AM. |
