Rapid Hitch
1 Attachment(s)
This hitch is rated for 1500 pounds tongue weight and 10,ooo pounds trailer GVWR. Does Rapid Hitch under rate their capacities, or should I play it safe and go to a steel hitch?
Re: Rapid Hitch
Would the factory Dodge hitch receiver work OK, then I just find the stronger drawbar and ball? I really like the Rapid Hitch but I think I'm exceeding the weight limits by a few thousand pounds. Time to make a change before something bad happens.
Originally Posted by Troutly
I would play it safe and go with at least a Reese Titan V with their draw bar and with a 20K or 26K ball. You have a lot of weight back there.
Re: Rapid Hitch
what he said. full overkill on the hardware...nothing marginal. |
Re: Rapid Hitch
Hey...the three of us have our own forum now! :cool:
It'll make the fountain guys happy. :D |
Re: Rapid Hitch
What's a fountain?
Re: Rapid Hitch
16000 pounds towing capacity. I'll just upgrade the hitch and ball. Really liked that Rapid Hitch :mad:
Might want to look, but I bet the stock hitch is only rated at 10K.....gawd knows the rest of the truck is only rated at 5K :p :p
The hitch, receiver, and ball is one area I'd not skimp on. You can buy and install a Titan V (or other true Class 5) for around $400. |
| All times are GMT -5. The time now is 10:38 PM. |
