In hull transducer mount
2 Attachment(s)
OK guys, I might have found where the factory installed the transducer in my hull. Mine is currently mounted on the transom because the marina I bought the boat from couldn't get it to read through the hull. The spot I found is pretty much right under the starter. I'll post up a pic of it. Should I try to grind it out some, or just glue it in and see if it works?
This is on a 280, and it is a Hawk Eye depth sounder. Thanks, Frank |
Because it is a cored hull, you have to use a hole saw and cut through the coring. Then the epoxy the hole and insert the transducer.
Scary isn't it? :D |
That's what I'm wondering. Does that spot look like it was done before? I think I'll have to try to grind out in that circle and see what's going on.
Does anyone with a 280 built around 98 have a factory mounted transducer that can verify the location? Thanks |
Frank,
My 22 Velocity has through hull and reads just fine. Not sure of the brand. |
Mine is a 98. Factory had me install it just about center-line and almost to the front of the engine. Give them a call and someone will walk you through it. Boat is in storage or Iwould e mail you a couple of pics. I can't check yours as I am not a paid member.
More importantly gentleman, Why is your motor out Frank?
I need specs...I refuse to be the back of the pack. Are you gonna force me to blow it. LOL No really 600..700...800HP, New drive? come on Give |
1 Attachment(s)
hmmm, I'm not sure I should devulge the top secret engine build.:D I am adding A/C though. That should offset any gains made by the extra hp from the AFR's, cam, intake, ect.:evilb: :D
Don't worry vicious you will be ok if I am part of the pack. I should be well behind you guys.
Frank, I would have made a good excuse for pulling the motor!! Good luck with the motor build. Dwayne |
Nova, for some reason I now get the pic and that looks like the spot.
Great. Thanks for the info!
Frank |
| All times are GMT -5. The time now is 09:56 AM. |
