-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Hatch Actuators (https://www.offshoreonly.com/forums/velocity/156580-hatch-actuators.html)
brian valery 04-23-2007 01:59 PM
Hatch Actuators
Anyone know the proper actuator for a 23 regal velocity i/o engine cover and price?
Vmax 05-28-2007 08:21 AM
Before you replace hatch actuator test it by hard wiring at the actuator pump direct to 12 V DC. I have the same boat. It will corrode at fuse box under right side rear seat. Clean corrosion and WD 40. Other problems are with two way switch. connection coming loose under dash or just burning out.
brian valery 05-28-2007 06:56 PM
Thanks, but the boat was missing the actuator when I purchased it. In the process of refub and am not sure of the actuator that came with it. i know that the meassure is 27" from the floor to the top of the hatch. I think it is a 22" actuator. Do you know what yours messures
Vmax 06-07-2007 06:03 PM
What measurement do you need. Fully extended? It comes with a stainless swivel link. It will retract about another 5 inches when hatch all the way down. It tops out quickly. My opinion cold usee another 5 inches of extension. Swivel link allows you to open hatch if power fails. My 22foot v100 had the same actuator. I would says a 22 would work. Tell me what dimension you need.
brian valery 06-07-2007 07:20 PM
The measure from the floor to the top of the hatch when closed is 27". I would like the hatch to open enough to change or check the oil, maybe 40"...
Vmax 06-10-2007 08:12 PM
Retracted length is 24" EXTENDS ADDITIONAL 19"
brian valery 06-10-2007 09:07 PM
Thank
