-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   right prop (https://www.offshoreonly.com/forums/velocity/160472-right-prop.html)
carsoncapps 06-10-2007 12:42 PM
right prop
89 23ft velocity 454 bravo one drive it will only go about 62mph at 4200 rpm that is with little trim because the prop slips.The prop is a 23 mirage plus with double cup and the blades have been rolled.
[email protected]
Vmax 06-10-2007 04:38 PM
What 454? The 330 horse or 365 mag engine. 23 pitch is right for either engine. What is your elevation where you boat? If the prop is not hooking up seems odd. With the 330 should be getting about 66 to 67 at about 4500 RPM Add 3 to 4 few easy with the 365 and some R's. Need the trim to get the boat loose up on the pad then nail it. My experience with the 22 and 230 need lots of trim up for speed. After 65 mph she'll take all the trim just give her more R's. Both boats I found run fastest with some rooster tail at edge of close to cavitating the prop. You'll have a smile and a shiny prop from running like that. Assume you have trim limit adjusted properly for 15 degree max thrust angle. My prop will cavitate at lower speeds with two much trim give her throttle while trimming up and she'll take it to max trim set for 15 degrees prop hooked up. Don't think because it is not hooked up slower that it'll be an issue at full throttle unless your trim limit is whacked. At 62 boat is just getting on the pad still feels like other boats. Boat feels much different after 65 mph. Believe me you'll know when your on pad. Check for 15 degree thrust angle setting at max trim limit set it there then enjoy for full throttle runs. I set it with boat on trailer using protractor and level aligned with drive cavitation plate. Be shure you set 15 degrees by taking into account the drive gimbal installs on a slanted transom. Exercise in geometry takes a little time. But it is set and forget after that. Don't have to worry about too much trim. I tried trailer switch for more trim after that she is a lost cause theres no more speed to be gained after that 15 degree thrust angle and standard bravo. 15 degrees thrust angle is max recommended by mercruiser.
Other possibilities do you have a nose cone issue on crooked or something causing prop to blow out? Assume you have 1.5 ratio too.
carsoncapps 06-11-2007 12:06 PM
prop
I have 454 330hp and it trys to get on the pad but cant because the prop slip with little trim.I cant throw a ruster tail period.I can if I use trailer but it vibrates really bad. 3 balde
mirage plus with extra cup is what I currently have.
pgatso 07-13-2007 07:36 AM
Any luck with your Velocity. Just bought a 1990 23'. Bone stock 454 330hp. Trying to find the right prop. I have a 24p High Five on right now. Great hole shots, but tops out a 58mph at 4950RPM. I did try a 23p 3blade and got 62mph at 4600rpm. Next I am going to try a 25p Mirage. Just wondering if you found the right prop for your boat.
pgatso 07-18-2007 02:37 PM
OOPS! Turns out that my High Five is a 21 pitch, not a 24. But I still need to know what is wrong with my boat.
