-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Proper x Dimension on a 23 Velocity (https://www.offshoreonly.com/forums/velocity/164407-proper-x-dimension-23-velocity.html)
brian valery 07-25-2007 07:33 AM
Looking for the proper x dimension on a 23 velocity with a bravo high performance outdrive?
spit 07-25-2007 12:16 PM
I believe you want the prop shaft about 3 1/4" below the pad which equates to about an 18 1/2" X. This set up works great for boats powered with 320 to 425 HP. If you have less HP than that you might want to lower it a bit to help get on plane.
