X dimension, prop shaft measurement
I measured the distance from the center of the boat bottom to the prop shaft centerline. It measures 3 5/8" below the boat bottom.. Is that a normal depth? I would be interested in what other Velocity 260 owners are seeing for that measurment? Has anyone tried a 1 or 2 inch shorty with any sucess?
I just measeured mine its 4" below the pad. I was wondering if I can find more speed with a 2inch shorty
are you guys getting the shaft level with the bottom if not it will change the measurement a lot i use a angle finder on the pad and the cav plate on the drive to get them the same
Originally Posted by mikes280
(Post 2348904)
I measured mine it's 2" below
Originally Posted by 28thoroughbred
(Post 2350191)
Originally Posted by BBILL1174
(Post 2349351)
I had the shaft level. He also said no one tried a shorty on a 26.
(Post 2350191)
(Post 2350674)
i have and my brother has to and yes you WILL need a 5 blade
(Post 2348904)
Originally Posted by Revd Up
(Post 2350805)
I just eye balled it, but the angle finder is a great idea. I will try that. Did you do any bottom work? Did you see any gains?
(Post 2353162)
no i did not, with a 4 blade boat would blow out coming up on plane. velocity mark ran one with a 5 blade and boat was no faster then with 4 blade and standerd drive he may jump in we both are going to try it again with different props to see if it will work 28 thoroughbred's boat works he raised the drive in the boat
Tyler Crockett told me that his old Velocity race boat ran best with a 3 " to 3 1/2" measurement with a 5 blade. Like everyone else, I'm just wondering if there is anything to be gained by raising my drive height , or straightening the bottom and sharpening edges. Figured someone has done it before and could advise whether or not its worth the time and $. Thanks, |
Straightening the bottom will get you about 2 to 3mph from what I have heard.:cool-smiley-011:
| All times are GMT -5. The time now is 01:39 PM. |
