-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   2 speedo's (https://www.offshoreonly.com/forums/velocity/183534-2-speedos.html)
Velocity Vector 04-02-2008 01:09 AM
2 speedo's
I hope you guy's don't mind but since I can't remove my recently installed Gaffrig GPS antenna because some dumb F$Ck followed the directions and installed it with 5200 adhesive, I didn't figure this out untill after I installed the Livorsi GPS antenna with some leftover 5200 adheasive "hint, hint". Now I have two GPS antennas Stuck tighter than a undercarrage bolt on 1936 catepillar. Since I still have the recently installed Gaffrig GPS speedo, "I only used it one time $475.00" I have decided to install the speedo where the remote stereo controler was on the passengers side panel that doesn't work anyway. I have already covered the panel with the same carbon fiber vinyl as the drivers side. I think it will look alright and it will keep the passenger informed without hoovering around my space trying to see how fast we are going and it won't cost me anything except a yellow bezel.
Here is a cut and paste of what it will look like.
http://i265.photobucket.com/albums/i...0/ffc1_1-1.jpg
RaggedEdge 04-02-2008 05:17 AM
Originally Posted by Velocity Vector (Post 2509746)
I have decided to install the speedo where the remote stereo controler was on the passengers side panel. I think it will look alright and it will keep the passenger informed without hoovering around my space trying to see how fast we are going.
You can just add the two numbers together to get your top speed. And it will save you all the money you are going to spend on those Whipples. :D
ThruHull 04-02-2008 06:53 AM
VV, if you decide you want to remove one antenna, you may want to try this stuff http://www.debondcorp.com/
Velocity Vector 04-02-2008 08:34 AM
Thanks Ragged, After filling up the other day these fuel pincher 496's are looking better and better. Now that I can double my speed with the two speedo's. I may just put those whipples in the tank. I shouldn't have any trouble going over a 100 now with the current set-up.:cool-smiley-011:
Velocity Vector 04-02-2008 08:36 AM
Thanks ThruHull, looks like some good stuff.
Velocity Vector 04-02-2008 02:08 PM
That little project didn't take long. Do you think I should even get a yellow bezel for the 2nd speedo or leave it like it is? I think if I did put a bezel on the gauge it would stick out like a soar eyeball.
http://i265.photobucket.com/albums/i...DSC_0010-2.jpg
http://i265.photobucket.com/albums/i...0/DSC_0014.jpg
http://i265.photobucket.com/albums/i...0/DSC_0012.jpg
http://i265.photobucket.com/albums/i...320/ragged.jpg
