-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Gauge Question (https://www.offshoreonly.com/forums/velocity/184865-gauge-question.html)
Sick Stinger 04-18-2008 04:33 PM
Gauge Question
Het guys just wondering what would you do with for a replacement gauge. And what size? Ive seen a lot of Livorsi and AutoMeter out there. Id like to get a set and have them popped in by next weekend. Also is there a direct fit replacement gauge or will i have to modify. Side note i have the scoop on my sunpad came out awsome ill post pics tomorrow.
-Mike
Velocity Vector 04-18-2008 05:55 PM
-Mike
The simple way is go with the same size gauge or re-do the dash and install monsters. I personally would go Livorsi.
Sick Stinger 04-18-2008 07:43 PM
Hey Vec id like the same size gauge are they 2 1/8 or the 2 5/8. The Speedo and Tach are 3 3/4 or something? I like the look of Livorsi. Do they have to be liquid filled just because the factory ones are not.
-Mike
Velocity Vector 04-18-2008 08:17 PM
-Mike
Monsters are 2 5/8 cut out and the reg. 2 1/8 cut out. Measure the size of your gauge not the lip on the front but the diameter of the back of the gauge or the actual cut out on the dash before you order. Some of the older gauges are 2" and some 2 1/16". Mine are not fluid filled, the speedo is 3 3/8" cut out 3 3/4 over all. Monster is 4 3/8" cut out 4 3/4 over all
Sick Stinger 04-19-2008 06:52 AM
Thanks Vec i will just pult the speedo and Trim gauge out and measure them
-Mike
Elite Marine 04-19-2008 09:06 AM
Livorsi discount through April!!
[email protected]
Kirk
