-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   260 Amp mounting (https://www.offshoreonly.com/forums/velocity/201007-260-amp-mounting.html)
jab052783 01-04-2009 06:04 PM
260 Amp mounting
I have a 260 and I am going to mount a amp for a 12'' sub but can not seem to find a location in the boat that I am happy with does any one have any suggestions
ThruHull 01-04-2009 06:15 PM
Do you have enough room to mount it behind the passenger side glove box? Where is your radio installed?
SIDE JOBS 01-06-2009 12:28 PM
I Mounted My Amps On The Back Wall In The Engine Room. I"ll Post Pixs
SIDE JOBS 01-06-2009 04:46 PM
3 Attachment(s)
Here Some Pics.
Velocity Vector 01-06-2009 04:57 PM
Mine are mounted behind the glove box inside the cabin behind the wall panel. So easy to access, just take out those 67 screws and molding around the door-way and pri-out the panel then patch any vinyl you rip or tear up.
Vicious22 01-11-2009 01:08 PM
I mounted amps up high in the closet and the sub went up front in the face of the V birth in the storage cab
jab052783 01-12-2009 04:59 PM
amp & sub mounting
Thanks for your help guys
