-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Active Thunder 28 savage vs 290sc (https://www.offshoreonly.com/forums/velocity/221218-active-thunder-28-savage-vs-290sc.html)
dennis1009 12-11-2009 08:00 PM
The time has come. I know two different hulls,but quality vs quality? The Velocity has a 496ho will do a solid 72 or 73 on gps. The Savage has a 525 and will run about the same. has anyone here owned both? I know the Savage will handle big water much better just wanting all the info before I pull the trigger as this saga has been going on for a couple of months now I have all the pieces in place to purchase. The Savage is a 2006 the Velocity is an 08. any info will be helpful. I will be doing most of my boating in sw fla the Gulf and down in the Keys.Thanks
Padraig 12-11-2009 08:24 PM
Two words, Steve Stepp.
Conman 12-11-2009 09:13 PM
The Savage is a true V hull if I'm correct it probably goes mid 70's with that power, they make a decent boat but I'll keep my 290SC.
Oh Deere 12-12-2009 11:34 AM
Did I miss something? Thought there was a done deal on a 290...
notda1 12-12-2009 10:15 PM
Sonic is a heavy boat and rides deeper , Velocity probably ride higher if you can get it up on the pad . You may get the same top end but , 525 will use more fuel , have shorter expected life span and be more expensive to rebuild
Velocity Vector 12-12-2009 10:42 PM
Don't think the 496's can't get expensive I blew one then blew 80K to fix it. Heee!
