looks great so us some pics when you get it in
Nice job.
Well, got the sub in. I ended up turning the box around so the sub is facing the front of the boat. The L7 moves so much air it was necessary to cut a vent in the plywood bed base and scre the bed base down with 1 screw every 4-5 inches to keep it from flexing and ratteling.
As far as pic, nothing really to look at since the speaker is facing forward. It would just be a picture of the back of the box.... |
Originally Posted by low_psi
(Post 3083026)
Originally Posted by cfo20
(Post 3085837)
How bad does it rattle the porti-poddy? Or anything else around there? I was thinking of dropping a sub in the same area, but I figured it would rattle the porti to pieces (although I don't use the porti).
(Post 3086107)
With the sub facing forward it doesn't bother the porta-potty at all. But the plywood floor for the bed will need to be screwed down about ever 3 inches. I also vented it by cutting a 6 x 12 hole in the plywood floor up at the front of the bed. without the vent the air pressure was causing the floor to flex and rattle. It's only 1/4" - 3/8" plywood so it doesn't take much to flex it.
| All times are GMT -5. The time now is 02:03 PM. |
