-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   What prop is standard on a 260 w/496 mag (https://www.offshoreonly.com/forums/velocity/227630-what-prop-standard-260-w-496-mag.html)
rmfriday 04-04-2010 12:05 AM
i have a marige 27p that will prop just blow out on you but if you really want to try a 3 blade you might get that last mph or 2
low_psi 04-04-2010 08:44 AM
Thanx, but I am going to order a 26p from hydromotive on Monday. They offer a pretty good exchange program, so If my boat doesn't like the 26p, they will exchange it.
mikes280 04-04-2010 09:53 AM
a 26 hydro will turn less rpm then a 26 bravo but with a 1.5 i still say that is where you need to start . when you get the 26 hydro test it and the bravo and let us know the difference.
low_psi 04-04-2010 10:10 AM
Here is a stupid question....
The 26p Bravo that I have is/was on a Sportmaster with a 1-1/4" Prop Shaft. I haven't looked at the prop very closly yet, but do these have removable hubs? If not I guess I won't be testing the 26p Bravo......
low_psi 04-04-2010 10:16 AM
Nevermind. I just answered my own question....
It's a solid hub. So it looks like I won't be testing the Bravo 1 26p that I have.
My boat will be pretty heavy as I usually keep 3/4 - Full tank of gas, Full Cooler, Stereo equip. 3 batteries, wife and daughter. So What do you think would be better a Bravo 1 or Hydro ? Again, I am not looking to squeeze every MPH out of the boat. Just want a decent top end, but will be operation at the low-mid range most of the time.
rmfriday 04-04-2010 03:55 PM
if you all ready own the b1 i would have a new hub pressed in it(should be under $100) and use it as my starting point. hell it should be in the ball park of what your looking for and you might be dead on with it.
mikes280 04-04-2010 10:12 PM
look at that hub again you should be able to knock it out . you can get the hub for the standered shaft
low_psi 04-06-2010 05:55 PM
Yup! The old hub came out and put a 1" hub in. I will keep it. After a call to Kenny @ Velocity, the 26P Bravo 1 is the prop that came on it.
