Step bottom trim tabs
http://i951.photobucket.com/albums/a...Picture324.jpg
http://i951.photobucket.com/albums/a...Picture327.jpg http://i951.photobucket.com/albums/a...Picture325.jpg Check out these tabs Ive been working on I put steps in the bottom to reduce drag, i cut them on my cnc machine out of billet aluminum . Did some back to back testing with the stock ones on my 1996 28 velocity with a hp500. I trimmed the same each time and found that they run the same speed within one mph when they are down at 7 to 3 one my indicator, 2 on my inductor is flat and found when they are there at wot 5000 rpm went 75.0 mph with the stock tabs and went 76.0 mph with my tabs. they work when you drop them a bit to help stabilize the boat. the boat goes 78-79 with the tabs all the way up. let me know what you think. |
Those are some insane membranous nephropathy glomerulonephritis tabs you built there look cool how do the work on the turns .
Only have about a hour on them going to do some more testing this weekend
So if I understand right, one of the goals is to reduce drag while they are deployed? Looks like you are seeing some benefit from that when running with them level--thats cool!
Originally Posted by kevinz99
(Post 3111856)
Nice Kev. What was the cost in making those also could you cut a gear on your CNC?
-Mike |
Thats pretty trick looking:drink:
Originally Posted by Sick Stinger
(Post 3113092)
-Mike |
| All times are GMT -5. The time now is 03:12 AM. |
