-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Velocity 320 thoughts (https://www.offshoreonly.com/forums/velocity/234292-velocity-320-thoughts.html)
Starflite X 07-14-2010 09:27 PM
Originally Posted by Revelocity (Post 3157093)
Correct - it is the original 30' hull.
I'm not so sure about that. The original 30 had an 8' beam. At least that's what a very old Velocity brochure says The 322 is 8'6".
Revelocity 07-15-2010 01:38 PM
Actually it's the same hull bottom but with higher sides to deliver the deeper freeboard and beam. Check out the angled transom corners on both boats!
Starflite X 07-15-2010 02:38 PM
Ah! That makes sense.
