-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   98 26 velocity speeds?? (https://www.offshoreonly.com/forums/velocity/257301-98-26-velocity-speeds.html)
rollnhrd 07-05-2011 05:11 PM
I got a 1998 velocity with a 525 with a blower built by performance just wondering if my speeds are some what correct compared to others with similar applications? ? 87.8 on gps with a full tank of gasand 98 on the dreamometer lol? Any input would be great thanks ...mike...
Velocity Tom 07-05-2011 07:30 PM
What pitch prop? and what rpm?
rollnhrd 07-05-2011 07:39 PM
30 bravo 1 4 blade done by b-blades at 5500
Velocity Tom 07-05-2011 07:41 PM
I could beleve 87 mph.
rollnhrd 07-05-2011 07:48 PM
i was actually thinkin i should be doing a little better.. i have a garmin gps im not a b.s.e.r lol.. i tell the exact truth not like others i see on here lol
gary cook 07-06-2011 10:48 AM
speeds
mike your speed is pretty close my 26 race with a 30 b blades 1.65 gear does 94.4 at 6500 that engine makes 715 hp.
my backup engine that is 615 hp same set up at 5500 goes 85 mph just to give you some comparsions these are real gps speeds not bs lots luck have fun.
also do you know how much power you are making.
rollnhrd 07-06-2011 12:42 PM
My engine builder said I should be deep in the 700 hundred range .. im running a hair over 6lbs of boost I got 2 800 holleys on it im just wondering if I could knock the jets down a hair.. I thought it would run a lil better but all in all im very happy..
Fast Shafts 07-06-2011 12:43 PM
Gary, with speeds like that you should be running class 4, not 6!:confused:
MrSneakAttack 07-06-2011 12:56 PM
Ive Had Two 26ft Velocity's.....your Speed Sounds About Right....anything Faster Is A Real Hand Full To Drive......been There Done That!!!! Be Safe!!!
rollnhrd 07-06-2011 01:02 PM
Its actually not bad with the bigger tabs and hydraulic steering. But I wouldn't wanna go that fast with out those 2 key items...
gary cook 07-06-2011 05:10 PM
speeds
Fast shafts in race trim its proped for 70 ish:cool-smiley-027:
Anyway what are you doing sneeking around the velocity section.:lolhit:
Fast Shafts 07-06-2011 06:31 PM
Gary-just keeping the competition honest!:eek: I can't make the Mich. races-hope to race against you someday-maybe Orang Beach?
gary cook 07-07-2011 12:55 PM
speeds
Bob give me a call when you get a chance thanks gary. cell 586-855-2807 shop 586-465-2120
