-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   headliner problem (https://www.offshoreonly.com/forums/velocity/260795-headliner-problem.html)
Padraig 08-22-2011 08:01 AM
headliner problem
The material lining the inside of the cabin (over head) is starting to sag. :eek: This is on a 1998 280 Velocity. Is there any fix or is it time to take it to a specialty shop?
Vicious22 08-22-2011 10:10 AM
Mine too
cabin fever 08-22-2011 11:00 AM
on my crownline there was no fixing it. The foam behind the headliner material was rotting, and even if you sprayed glue behind it, would only last a few days. I ended up replacing it myself. Not to bad of a job.
Not sure if the Velocity is the same or not. Luckily mine is still holding up pretty good.
Padraig 08-22-2011 11:11 AM
What was involved with replacing it and where did you get the material???
Thanks,
cabin fever 08-22-2011 01:47 PM
Took all the trim off first. Then started tearing the old healiner out. Mine had some 1" foam glued to the fiberglass, then the headliner material glued to the foam.
I bought the headliner material from a local upholster, and the foam I bought online. I used 3m spray adhesive. Make sure you use the stuff in the black can. As I recall it was about $25/can, and it took 2 cans.
clean the old glue off the fiberglass as best you can, then spray both the fiberglass, and the back of the headliner / foam
I had to have 2 pieces of headliner material sewn together to cover it. I left it long, and came back, and trimed it with a knife after it dried. I think I had about $300 in it, and turned out pretty nice.
cabin fever 08-22-2011 01:48 PM
Oh yea, go to a Home Depot or somewhere and buy a roll of the plastic they put over carpet, and cover EVERYTHING. The glue goes everywhere.
be preparred to get real high when spraying the glue in teh cabin. I was looped. Even with a mask.
patrird 10-10-2011 08:28 PM
How did you remove the foam from the fiberglass?
