-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   260 with 496ho (https://www.offshoreonly.com/forums/velocity/288327-260-496ho.html)
trex232 11-30-2012 10:02 AM
260 with 496ho
What speeds can you expect, how do they handle 2-4 ft wake
Revelocity 11-30-2012 10:29 AM
That's a popular boat so you'll likely get an actual owner to reply. Do you mean 2 to 4 seas? No boat like steep 4' boat wakes!
trex232 11-30-2012 10:51 AM
yes 2 to 4 ft seas
Velocity Tom 12-01-2012 09:28 AM
You will have to drive it in 2-4. My bud had a 260 with a 496 375 hp it ran 65mph. My brothers 280 with a 496 425 hp ran 72 mph.
Redhook98 12-01-2012 10:33 AM
My 2000 260 with the 496HO can hit 74 in premium conditions. Maybe a touch more if I get some prop work done, etc. I can consistently run 70 though with another person or two onboard and medium fuel load. I cruise at 55 or so to conserve fuel. For anything over 60, you really need at least the external hydraulic steering. (full is recommended). I have the external only and you REALLY feel the slop in the cable at 65+!!! This is the only reason I have not pushed it further with a labbed prop.
As for 2-4 foot wakes. Let's just say it is a fun ride. Make sure you take them at a 45-degree minimum angle (or head on) when at speed and hang on. The boat feels very solid in rougher waters, but it is a hairy ride due to it's size and weight. Having just stepped down from a 34-ft Sea Ray, it was a re-learning experience.
underpsi68 12-01-2012 12:29 PM
Do you know what prop your brother is running (280/496ho)? I have the same setup and need a prop.
Velocity Tom 12-01-2012 12:34 PM
I think he ran a 27 labed hydro. Call Mike at hulls or Kenny at the factory.
Redhook The 26 running 74 with a 496 is it a mag ho 425 hp or 496 mag 325 hp.
Redhook98 12-01-2012 02:47 PM
It is a 496 Mag-HO (425 HP). I am running a stock Bravo II 26p prop.
Velocity Tom 12-02-2012 09:35 AM
I run a 29 hydro on my vr1.
gotstreetracin 12-03-2012 05:22 PM
i got 71.9 in my 260 with 496 mag & 28p labbed bravo 1
