-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Best prop for a 2000 260 (https://www.offshoreonly.com/forums/velocity/295616-best-prop-2000-260-a.html)
trex232 05-02-2013 07:32 AM
What is the best pitch to run on a 260 with a 496 mag
ThisIsLivin 05-02-2013 10:32 AM
What do you have now and how does it run?
trex232 05-02-2013 02:36 PM
260 bravo1 but I am hitting rev limiter, that is with no hatch or back seat, 3 200lb men. I have some throttle left
trex232 05-02-2013 02:37 PM
26p bravo but I am hitting rev limiter, that is with no hatch or back seat, 3 200lb men. I have some throttle left
Padraig 05-02-2013 10:13 PM
I would go with a 26 hydromotive 4 blade or go up a couple of inches with a Bravo One.
ThisIsLivin 05-03-2013 06:33 AM
I have a 27 Hydromotive 4 Blade that is fresh from the factory that I'm trying to sell.
trex232 05-03-2013 07:39 AM
how much, thought about a 28 bravo1
Redhook98 05-03-2013 11:38 AM
I run a 26p Bravo I on my 2000 260. That is also the same prop that it comes with from Velocity. A 28p may work, but only with a light load. I was told to stay away from Hydros as they had to much lift for that hull.
With a non-labbed 28p, you may be working the engine too hard for 2-3 mph more. The best prop is one that allows you to reach your highest rated RPM (or with 200rpm) with a normal load onboard.
I hit about 74-75 when the needle reaches 5100 with a nominal load (two people onboard (including myself), dual batteries, 1/2-3/4 fuel, hatch installed and all play-things on the boat).
Get the seat and hatch back in, with a normal load of fuel, beer and friends, and then try that 26p. I have the HO version of your motor and it is near perfect. If you go 28p, get it labbed first.
VELOCITYBOY 05-03-2013 05:00 PM
Hydros work great on the 260's at top end. The bravo works better at low speeds to mid-range. The five blade PX hydros works all around better than bravos if you have hp to push it. The boat on a hydro lifts the bow more. I ran a PX 28 on my old 260 with a blower motor, loved the prop. great cruising speed to top end with an assume hole shot, far superior to any bravo even labed.
trex232 05-04-2013 02:08 PM
Redhook, how do you turn 5100 rpm, the rev limiter comes in on mine at 4800-4900 rpm's
Redhook98 05-04-2013 03:25 PM
The rev limiter on the HO is 5150 rpm.
trex232 05-18-2013 01:46 PM
ran the boat yesterday half tank of fuel, 2 adults everything back inside, still hit the limiter with throttle left, what about a hydromotive prop
searaycer 05-18-2013 04:51 PM
they like Hydromotives, I have a worked 27 on mine and a stock 27 as a spare, I could use way more prop with the new power, but I like the slip factor so i am not working the XR too hard.
