-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   320 questions (https://www.offshoreonly.com/forums/velocity/297757-320-questions.html)
cabin fever 06-07-2013 10:09 AM
320 questions
What kinda speeds with 7.4's (non mags)? Also how long (on avg) is it on trailer? My 280 fit in my shop with over 4 ft. Am i thinking this right or is the 320 a true 32 ft boat. Wife gave the greenlight to spend some $
Revelocity 06-07-2013 03:26 PM
You'll be in the low 70's with 330 HP 7.4 carb motors and another 1 or 2 with the 340 HP 7.4 MPI's.
The 320 is 32' including the swim platform. Prior to being called the 320 it was called a 30-32. 30' running length with 32' overall length.
It's been a quite a few years but I'm faily certain my triple axle 320 set-up was more then 4' longer when parked next to a 280. Sorry I don't have any measurements.
ziemer 06-08-2013 11:01 AM
It will depend on the trailer for overall length. My steel trailer had a real short tongue and it was 33' ish...however my aluminum adds a couple feet. The pole barn I built for my 30' is 36' overall and I can fit everything on the 36' slab. (not by much though) Mine is an older 30', but they're probably fairly close
Velocity Vector 06-09-2013 01:18 PM
If you back it in there really fast and done stop till the hitch clears the door it will most likely fit.
Vicious22 06-10-2013 11:08 AM
Well if you are looking for a 320 deal....this is it. I know the boats history. This is the fastest 320 I've ever seen.
Used 1996 Velocity 32 Thoroughbred, Kent Island, Md - 21638 - BoatTrader.com
Velocity Vector 06-10-2013 05:19 PM
That's Bills?
