-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Bilge Pump Fuse on 280 (https://www.offshoreonly.com/forums/velocity/313771-bilge-pump-fuse-280-a.html)
Hotdog1922 06-14-2014 10:16 AM
Since I bought the boat there was a inline fuse and a spot for a spare connected to the battery. There was never a fuse in it. The pump works from the switch at the dash but while I was filling the bilge with water to clean it I noticed the pump didn't go on by itself. Could this be for the pump float? And if it is what size fuse goes there?
Revelocity 06-16-2014 07:09 AM
Although Velocity generally didn't connect the float switch directly to the battery - this is a tried and true approach. While the fuse size depends on the pump size, I'd suggest trying a 10 amp and moving up as needed.
