-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Low oil pressure (https://www.offshoreonly.com/forums/velocity/325947-low-oil-pressure.html)
Beachwood 05-06-2015 10:31 AM
Low oil pressure
I get an alrm and my oil press guage drops to zero when i come off plane when running hard for an extended amount of time. This has happened twice .If I run around 3400 to 4000 it doesn't do it. I have check the oil all os good. Not sure what direction to strat to figure this out. Thanks Mitch
Vicious22 05-07-2015 07:32 AM
Check the wiring to the sender. Something may be loose and move when the boat decelerates.
Beachwood 05-07-2015 07:37 AM
I did check that doesn't seem to be loose.thanks though
3pointstar 05-07-2015 08:37 AM
Years ago - this was a straight 6 165hp Mercruiser- it was a VERY HOT Labor Day - I ran this engine for an extended period WOT. I came off plane and the exact same thing happened- oil pressure went to zero, lights flashed etc. I immediately shut the engine down and brought it back to shore. I let the engine cool off-- checked the oil - and it was full - no milk or anything- looked perfect. I restarted and again no oil pressure -- Took it to my mechanic thinking the oil pump may have broke- or worse. When I called the next day - his associate said that he was out on the lake running around. Turns out nothing was wrong with the oil pump, sensor or wiring -- The oil broke down. All they did was change the oil and filter. Up until that episode I was using a straight 30W oil - Rotella -- Never had one bit of problem. Was told that Merc changed and now the recommended was 20-50W. I changed to this weight and never had any issues whatsoever-- Probably put on a good 200 hours after that before I sold the boat.
3pointstar
Beachwood 05-07-2015 08:41 AM
Cool thanks for the info. I am planning on putting a goof 40w in it when i get home from work in a couple of weeks.
Powerquest230 05-07-2015 07:11 PM
If pressure only drops after running hard how are your oil temps? If oil temps are rising I'd be looking into oil cooler etc..
Beachwood 05-07-2015 07:13 PM
I dont have an oil temp guage but i will check it and the oil cooler thanks
ROB FREEMAN 05-07-2015 08:44 PM
Get a mechanical oil pressure gauge. Shoot the oil filter after hard run with laser temp gun. It also recommend Mobil one v twin oil. It doesn't break down under high heat load conditions . Just a couple suggestions. Good luck
Beachwood 05-07-2015 08:47 PM
Thanks for the info. I have been told by several people to try kendall gtx 40w with a fram hp filter.
SB 05-07-2015 10:40 PM
Is this a new motor ? If so could be bypass sticking open for a few.
Beachwood 05-08-2015 05:54 AM
It has 350hrs
ROB FREEMAN 05-08-2015 02:26 PM
when you change that oil . cut open the filter n look for signs of bearing material .
Ryan00TJ 05-08-2015 08:52 PM
I agree with verifying psi thru a mechanical gauge. What oil are you running now?
Beachwood 05-08-2015 08:55 PM
Im not sure i just bought it from a friend .i believe it may be 20w40 the oil looks good. Bit when i get home from work in a couple of weeks i and going with 40w and good filter. Im thinking maybe changi2out the oil sending unit as well.
