Velocity 260 Engine Hatch Replacement/Help?Advise
While I'm in the mod stage on my boat, I'm not real happy with the Engine Hatch Lift unit's location......WAY-WAY to much stress on the hinges, lift and the hull where the hinge is bolted through. Looking for help on ideal placement for a new lift on a single engine, 260 Velocity giving maximum lift/hatch opening. I'm looking at using a single LENCO ball screw lift if at all possible, I've heard there pretty good units. Got, any pics or advice on this subject ? They'd be greatly appreciated, thanks.
Here's a pic when I bought it, motor end of lift is right above the transom assembly and hatch pivot is at the center of the hatch: http://i177.photobucket.com/albums/w...y.jpg~original |
I think this was the first set up that I've seen like this requiring the the plastic engine cover to be slotted. There's always pro's and con's. My 22 has a similar short ram mounted on the transom but more off-center. It's nice that it's lifts the hatch very high and is out of the way but does stress things as you mention. My 280 has two long rams mounted on the lower bulkhead straddling the front of the engine. The plus is that it's very secure and definitely keeps the hatch closed. The downside is that the rams slightly interfere with engine access and even with the very long rams - the hatch opening isn't that great. I would think buying a second ram like you already have, and locating both rams just outboard of the exhaust hoses, would give you all the benefits you currently have while cutting the hatch and transom stress in half.
Yeah, my ram leaves allot to be desired in its current state, it's a wonder the hatch hinges didn't pull out over time. I went ahead and ordered a Lenco (ball screw ram, one for now may do doubles if needed) P/N20778-001, 33" retracted and 53" extended. My plan is to mount the ram just fwd of the Port exhaust manifold hugging the motor. I plan on using removeable pit pins at the top and bottom so if something needs attention in the general area, pull 2 pins and the ram comes out. Top hatch mount will be a slotted mount allowing access to pull the pin in case of a power failure. Mounting it in this location should be allot easier on the ram as well as give me 38" of opening from the closed position, right now it only opens about 18". Pics will be forth coming once I start the install.
Side note: I went to unscrew the Port side bolster seat from the floor to make it easier to finish wiring and rehanging the wire harness since I've added the 2 hydraulic hoses in that bundle as well as side LED lighting strips, well to my surprise 3 of the floor screws were some how attached with nuts below the floor, I heard the nuts drop as I unscrewed those 3. All the rest were sheet metal type screws. How the hell did someone put nuts on those 3 screws ????????????? |
You can always make a new one out of foam core. Mine weighs maybe 40 lbs and is bomb proof.
The bolsters typically use a special type of plastic & stainless anchor that gets inserted through the floor. Can't remember the brand at this second. |
Originally Posted by speeddemon651
(Post 4394011)
FLOOR INSERTS FOR BOLSTERS SCREWS FOUND:
I guess I got my own answer..........I pull out one of those floor inserts and it had the name "TOGGLER" embossed in the head. After a little web and image search, found what I thought they were, went off to LOWES to pick some up. They do need to be modified before usage, not a big deal. If anybody may need this info in more detail. let me know and I'll post up some pics, P/N's and what has to be modified before use. |
You can call me you cant get them at Lowes Kenny 407-402-0300
Originally Posted by 90profx
(Post 4395977)
I guess I got my own answer..........I pull out one of those floor inserts and it had the name "TOPPER" embossed in the head. After a little web and image search, found what I thought they were, went off to LOWES to pick some up. They do need to be modified before usage, not a big deal. If anybody may need this info in more detail. let me know and I'll post up some pics, P/N's and what has to be modified before use. Padraig |
My bad, the correct product name is "TOGGLER" and not TOPPER, sorry for the error.
Kenny, just an FYI, I did pick up a box of these (10 pcs for $12 at LOWES), now mind you that these are plated steel and that the ones originally used by Velocity may have been stainless, but that's ok as they'll be sealed against water/rust. Mfg. site: http://www.toggler.com/products/snap...stallation.php Lowes Info: TOGGLER 10-Pack 1/4-in x 2-1/2-in Toggle Bolts Item #: 118084 Model #: 50425 http://i177.photobucket.com/albums/w...w.jpg~original |
This thread got totally misdirected (my fault) as it started as a Hatch Lift Thread, well here's the LENCO ball screw Hatch Lift installed. Now this is more like it, lot's of room to access the engine room. Still have to pull the sun pad off the hatch to
remove some sort of bracket that was part of the original lift attachment point. That'll be a good time to repair some stripped out holes in the sun pad that were missing screws. http://i177.photobucket.com/albums/w...a.jpg~original http://i177.photobucket.com/albums/w...r.jpg~original http://i177.photobucket.com/albums/w...y.jpg~original |
Thanks.....Looking good!
Sorry my mistake Lowes does have Toglers I only use Stainless and those are not Sorry again did no know you didnt want stainless in a marine environment
Originally Posted by letstalkboats
(Post 4396350)
Follow up on the sun deck removal.............:-(, looks like more work needed rolleyes:. Fiberglass is cracked on the 90 degree joint that the hinge bolts to allowing lots of flex, surprised it hasn't cracked the inside of that area of the gel-coat. I think the cracked glass was do to the angle of the original hatch lift, which actually put allot of lateral force on the hatch.... ::eek:: Not really a great design, very little bracing in its construction. Looks like I'll be getting out the fiberglass and resin to do some patch work and add some supports gussets, just when I thought I was getting close to being done.........:mad. Since I'm going to do all this glass work as well as add some aluminum plates on the hatch, I've decided that I'll be adding another LENCO HATCH LIFT to reduce the out of square lifting by the new one I've installed that's placed off center. This should give the hatch a long, long life without further issues once I'm all done. Pic's to follow.............
they have a nut on a zip tie thing u pull tight
Second LENCO ENGINE HATCH LIFT installed, I'm like'n it allot better with two lifts:
http://i177.photobucket.com/albums/w...p.jpg~original Now it's onto some fiberglass work to add a little support back at the hinge area which I'll post up in the "MODS" thread. |
| All times are GMT -5. The time now is 06:26 PM. |
