-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Brow Decal (https://www.offshoreonly.com/forums/velocity/337043-brow-decal.html)
DBO 05-03-2016 10:58 PM
Brow Decal
Not sure if others need or want a new brow decal ( that's the one on front of boat) but mine was weathered. My boat is an 02 and looks brand new with the exception of the front VELOCITY decal. I called Kenny and done, it's on its way for $100.00 US. Side decals look good so no need for those. Thanks again Kenny!!!!!!
cabin fever 05-04-2016 08:17 AM
Is it the same dimensions as the old one? Mine has a small spot missing in the "y". Got a little agressive with the buffer
DBO 05-04-2016 11:14 PM
I believe so but can't say for sure until I get the new one. I will update post when I get new decal. Stay tuned!
cabin fever 05-05-2016 08:03 AM
Thanks.
90profx 05-09-2016 05:51 AM
Need some pics when it's on..................
DBO 05-09-2016 09:37 AM
I will take before and after pics.New decal should be here tomorrow so i need to get busy getting the old one off!! Im sure that process is gunna be pain in the a$$.
Spent hours this week polishing and waxing the bow, half way done! Its a process that i like to do once a year.
90profx 05-09-2016 09:45 AM
Cheap Harbor Freight Heat Gun ($10), makes the job a piece of cake.
DBO 05-10-2016 11:34 AM
That heat gun sounds like a great idea. I was debating on possibly getting some sort of mineral spirits but wasn't sure about how that would effect my gel coat. I like the heat gun idea better, decal should be here today!!!!
DBO 05-10-2016 06:58 PM
Ok decal is here. I guess I will have to do each letter individualy because the arch is different on the boat . That may make the job a bit easier. Keep you posted.
90profx 05-11-2016 03:58 AM
Heat gun to remove letters and if your arch area is gel coat, acetone to remove any sticky residue followed by a good widow cleaner with ammonia in it, than it's clean enough to apply lettering.
DBO 05-26-2016 03:39 PM
Well have the old decal off and in the process of applying new one. Really not to bad of a process. Pics to come soon, looking really good so far!!
Hotdog1922 06-02-2016 09:02 PM
How do you get ahold of Kenny?
letstalkboats 06-03-2016 04:24 PM
LTB Performance Kenny 407-402-0300
