-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Took apart a perfectly GOOD running boat... (https://www.offshoreonly.com/forums/velocity/344667-took-apart-perfectly-good-running-boat.html)
CJSYD 07-07-2017 11:55 AM
Man that's terrible news! I was looking forward to some good news and big numbers as well... sorry man! Try to enjoy the rest of summer with the 496... you'll be back soon with the huffer connected!
Boatally Insane 12-19-2017 07:37 PM
ALMOST ready to try again... :)
New bearings in the engine..
Holley HP EFI
Holley Dual sync distributor
Holley 120Lb injectors...
https://c1.staticflickr.com/5/4732/3...025b2efe_b.jpg
Padraig 12-20-2017 08:28 AM
Good luck. Let us know how it goes.
Padraig
CJSYD 12-20-2017 08:58 AM
Nice! Did you figure out what happened?
Boatally Insane 12-20-2017 10:00 AM
More or less....
Engine hydrolocked from an injector sticking open..
Injectors were too small so I had raised the fuel pressure.. They didn't like that.. lol
Much of what I thought was metal in the oil, turned out to be silver paint.. Found I had gotten over-spray on the valve springs when I painted the heads..
I replaced all the bearings again as they were showing some wear...
The distributor hold down boss in the intake manifold had broken allowing the distributor to pop up out of the oil pump, so it ran without oil pressure for a couple minutes before I noticed it...
Other than that.. everything looked good...
CJSYD 12-20-2017 11:26 AM
Good investigations! Sounds like you're ready to go, and again... looking forward to the results!
Boatally Insane 12-28-2017 03:31 PM
It's been quiet in here.. figure I may as well post some NOISE... :)..
Bummer.. can't seem to get the video embedded... :(
Tiki Joe 12-28-2017 04:21 PM
https://youtu.be/f6qgY_mrRXk
https://www.youtube.com/watch?v=f6qgY_mrRXk
if you're quoted....I think it shows up
Padraig 12-28-2017 05:16 PM
Yep, works Tiki Joe's quote. Sounds good but dam....you don't have snow!
Padraig
Boatally Insane 12-28-2017 07:54 PM
Padraig
I ran away from than white crap 10 years ago
Hell ! last year at this time I was ON THE WATER !! :boat:
It's been a pretty chilly winter in Texas this year.
Heading to dyno Jan 10th.. :)
