496 Coolant Block Drain locations
Any pics available ? I've searched the site for the locations of the coolant block drains and their location is supposed to be just below the motor mount at just above the oil pan seal, is this correct ? Cause I sure as hell can't see them, what a jungle down there. Tips and tricks will be very welcome..................
Thanks |
They're 18mm hex plugs that have an 8mm allen pattern also in the head. They're obviously black and hard to see.
The starboard one is almost but not quite behind the oil dipstick tube and blends in very well.... Don't pull the large allen plug on the port side of block. It is a casting plug. http://i77.photobucket.com/albums/j7...87896829-3.jpg |
Originally Posted by Ryan00TJ
(Post 4539104)
The starboard one is almost but not quite behind the oil dipstick tube and blends in very well.... Don't pull the large allen plug on the port side of block. It is a casting plug. http://i77.photobucket.com/albums/j7...87896829-3.jpg Thank you very much. I got frustrated and quit looking for the day. I'll hit it again tomorrow. Based on your pic I now have a better idea of where to look for a needle in a hay stack............:p:D |
| All times are GMT -5. The time now is 06:36 PM. |
