-   Velocity (https://www.offshoreonly.com/forums/velocity-40/)
-   -   Hydromotive or Bravo? (https://www.offshoreonly.com/forums/velocity/68409-hydromotive-bravo.html)
Chase910 01-09-2004 06:06 PM
Which prop works best on this hull? Back when I owned mine it was the Hydromotive and that's what came shipped from the factory...is this still true?
VT32SSR 01-09-2004 06:25 PM
The mid range cruising is much better with the Bravo1. I have a 28 4 blade on a 280',and it works awsome.55 mph at 3500.
Steet 01-11-2004 10:46 AM
Bravo or Hydromotive
Bravo will usually work better for planning and cruising, but by far the hydromotive will have a better top end than bravo. Usually about 2 to 3 mph more top end
velocity260 01-15-2004 07:03 PM
I like the bravo as well
mr_velocity 01-20-2004 11:15 AM
I really like the labbed Bravos over the Hydros on my 41, it's a much better all round prop. I only see about 1 mph difference in the top end but I like the way the Bravos handles much better. I think in the rough stuff the Hydros are a little easier on the drives. I went 5 years without breaking a drive, the first year with the Bravos and I busted one.
Mad Hatter 01-20-2004 02:52 PM
Here's my results, tested a bunch of props last summer.
Hydromotive: Didn't get the best topend but handling and holeshot where decent.
Bravo: 2nd best topspeed, best handling in rough water (by far) and at cruise speed.
Mirage: Best topspeed and topspeed handling. But the worst in the rough water. Easiest to keep "on the pad" at topspeed.
I've resorted to keeping my bravo in the boat incase it gets rough. I haven't actually bought the mirage yet but its on my boat and I'm planning to buy it.
BTW I have a 22' w/ hp500 so its a single, characteristics change completly when talking about a twin
Vmax 01-20-2004 10:35 PM
MAD HATTER,
I have a 230 Velocity 1989 was part of the Regal years. I'm running a supercharged 454 with 550 dyno horsepower and external hydraulic steering. Have 27P mirage with 1.5 Bravo crescent nosecone. Boat seems to want a lot of positive trim to keep from pushing off the pad onto the bow when running over 5000 RPM. No handling issues at all if trim way up then accelerate. If try with neutral trim or slight positive and she is a handful. Rides on rails if your trimmed up first. Do you see this with your 22? My previous 22 Velocity never had any of this bow steer but just had the 454 mag. The 230 cooks with the SC when she is trimmed right. What pitch mirage do you use with the HP 500 and how fast does she turn it. Trying to dial mine in but still can easily turn to 5500 RPM on a cool day a lot tougher at 100 degree day. Found the mirage will ventilate easily accelerating in a turn. Thinking of sending it in for a lab job.
Vmax
Mad Hatter 01-20-2004 10:53 PM
I'm also running a 27p mirage, its hitting the rev limiter right now, I tried a mirage 29+p and that was just way to much prop. So I'm thinking like a 28+p might be the trick. When I was testing I would start at nuetral, go WOT and then start trimming because each prop seemed to like different trim.
With the bravo it felt like the nose just wouldn't come up, at all. It never felt like it was on the pad. Which leads me to believe my x dem might be a bit low. I like to try an IMCO shorty but not to many people would just let you "borrow one." Especially if you don't have the money to replace it if you break it.
I got beat by a 38 cig last summer so I gotta get my speed up to snuff, it should be a mid to upper 80's boat from what velocity is telling me.
Vmax 01-21-2004 11:31 AM
I'm thinking 28P would be about right also to knock a couple hundred off from the RPMs up top. Right now it planes fairly fast with all the SC low end torque available. I think I'm running at least mid 80's now with the RPMs. I have been considering sending my mirage off for the accelerator upgrade by Houston prop to fix blow out issues. Maybe having it repitched to 28 would help also. Let me know if you try a 28 mirage and how it works.We are probably somewhat close on installed horsepower given my side exhaust and mufflers. Seems I have to run a slight rooster tail to stay on pad and get out of the bow steer issues. My 22 velocity had a little less X dimension than the 230 and staying on pad was never a issue. Getting on plane was slow though.
Vmax
kidrock 01-21-2004 03:03 PM
STEET HAS IT RIGHT:fish:
