Fuel Pump and Reg support 1000 H.P.
Looking for an eltric fuel pump and reg to support high H.P. I have a holley back and have to keep the pressure real hight to keep the fuel there. I dont know the best option but im thinking aeromotive. Let me know
-Mike |
I have twin 1100hp PSI supercharged motors in my 38 Cigarette. I use a modified manual, 6 valve, fuel pump for normal cruising and have 2 Weldon marine electric pumps augmenting the mechanical pumps under boost. The Weldons are hooked to a hobbs pressure switch that is triggered @ 4lbs of boost/pressure to "come on". I have lights on the dash to indicate when the el. pumps are "on" and I monitor the fuel pressure guages when I'm under boost to see that all is well. Hope this helps.
Gary |
Thanks Gary. Im looking to run one pump with a boost referance pump. I had a guy PM somethign that looks like it will work its an SX pump and reg. the reg is pressure monitored to allow more fuel when needed (i assume).
-Mike |
I have run the Aeromotive Black pump, filter and regultor on my TPI 1100 with no issues.
aeromotive makes a pump called the eliminator. That one works good for me.
i will look in to them thanks guys Elite do you sell the aeromotive stuff
pumps
Originally Posted by Sick Stinger
(Post 2608846)
140's wont support it i have a 140 now
(Post 2610722)
I only want to run an electric with a boost refeance reg
| All times are GMT -5. The time now is 03:47 PM. |
