-   Wanted (https://www.offshoreonly.com/forums/wanted-244/)
-   -   Big CUbe blower motor shortblock (https://www.offshoreonly.com/forums/wanted/191877-big-cube-blower-motor-shortblock.html)
Sick Stinger 07-25-2008 09:09 AM
Looking for a big cubic inch short block. 540-999. Has to be for a blower motor. This maybe cheaper then getting a set of one off pistons for my motor. It was a 572 supposidly so something around there preferably. Looking to make 1k h.p. Thanks
-Mike
Essex29 07-25-2008 11:18 AM
-Mike
Mike,
How's the drive holding up? Is this for the new motor yhou just had built?
I have a 540 long block that I am looking to part with. Merlin block, J & E Blower pistons, rings and bearings
Scorpion Roller Rocker Arms
Lunati Custom Grind Cam (I was undecided during the build and also bought a Lunati Cam for running the motor w/o a blower, you get both).
Scat H Beam Rods
ARP Rod Bolts
Merlin Aluminum Heads Ported ( have flow sheets)
Mellings High Volume Oil Pump
Other misc. thing done are lifters, 5 angle valve job, magnaflux and micro polish crank, timing chain, new chromevalve covers. If your interested I can get you more info.
built for a 1k hp blower application.
Tarek
Coolerman 07-25-2008 11:38 AM
Here is a nice package that is dialed in, and runs great!
http://www.offshoreonlyclassifieds.com/2_complete_1100hp_packages-o24600-en.html
Blue242 07-25-2008 01:06 PM
Blower motor
Mike,
If this interests you, send me a PM.. It can do 1k HP with no problem.. Currently has a single plane Merlin carb intake on it, but if you wanted to put another intake manifold, it would be very easy... I also have a new set of Fel Pro Marine Head gaskets in a box, that I will throw in if you buy it..
I'm not in a hury to sell it as it's an extra motor in the garage. For the right offer, it can go. Like I said, I have a couple more spares...
Let me know,
Richard
Engine Block 588 CI 4.56 B X 4.50 ST
GM BBC Bowtie 10.2 Tall Deck Internally Balanced Roller
4 Bolt mains with ARP Studs
Clevite Race Rod and main bearings
Mahle File fit ring set
4340 Forged internally Balanced Crank, 4.50 Stroke
4340 Forged H Beam rods (6.535)
Arp L-19 Rod Bolts
SFI Internal Balance Dampner
Billet double roller timing chain w/Torrington bearing
JE 181996 Forged Pistons (4.56 bore X 1.395 CH) 9.0 : 1 Compression
Heads
Edelbrock Victor 7760, 24 Degree Rect Port Heads
(good to 8,000 RPM)
Fully ported with 118cc Chamber
Assembled for .660" max Lift
Ferrea Stainless intake 2.30, and Inconel Exhaust 1.90 Valves
1.63 Valve Springs
10 Degree Retainer Locks
Crane Double Bar Stud Girdles
ARP Head Studs
Comp magnum Roller rocker arms
Camshaft
Crane hydraulic lifters +.300
Custom Grind Cam Motion Hydraulic Roller Cam
Lobe Center Separation 114
Overlap 20.2
Intake/ Exhaust
Rocker Ratio 1.7/ 1.7
Duration@ .050" 242.6/ 253.8
Opening 11.3/ 64.9
Closing 51.3/ 8.9
Lobe Center 110/ 118
Lobe Lift 0.372/ 0.380
Valve lift 0.632/ 0.646
Sick Stinger 07-25-2008 01:54 PM
I have a top end need a short block i have dart pro 1's crane cam rockers and girles along with Hippo lifters. !0-71 bds blower with intercooler and carbs with evrythign else just need a rotating assemeby in block.
Smitty 07-30-2008 06:34 PM
I've got a Gen 6 shortblock. Tell me what you want me to put in it as far as pistons and crank and we can make a deal. Block is bored .030 and ready to go.
502ss 08-27-2008 03:15 PM
Mike,
You still looking for a short block?
kickin32 08-28-2008 10:35 PM
Originally Posted by Essex29 (Post 2634695)
Mike,
Scat H Beam Rods
ARP Rod Bolts
Tarek
interested in this motor pm some more info thanks
