trs bellhousing oil coolers
anybody got a set for the engine and trans with covers?
I have a few how many do you need. pm me . Tom 516-609-0499
I would not buy used ones unless you know history, you cannot flush them out if there was bearing issues, you will smoke mains if you get a bad set, if you can verify and trust person for used fine, but be aware they CANNOT be cleaned out...
I have two freshwater off of running take out 420's with Trs drives
Chris 585-978-0391 |
Originally Posted by Full Force
(Post 3970507)
Pull a fitting and look inside... The honeycomb design don't allow it...now way to get bearing particles out
bc, don't worry the ones you bought came off a motor that did not blow up. They were upgraded to larger 13 plate coolers. I would not resell coolers if the motor had a failure. Tom
Originally Posted by TomFTM
(Post 3971147)
| All times are GMT -5. The time now is 08:56 PM. |
