GPS speedo antenna
looking for older style 3 wire Livorsi Gps antenna or reasonably priced replacement. Don't mind updating if possible and will hopefully solve the internal dead battery problem for good!. Thanks, Holden 914-262-1898
Have you tried connecting your speedo to a Chartplotter w standard NEMA output to see that the speedo still works? Does your speedo cycle when you turn it on? If so the connecting this antenna/receiver may work for you. If not then just return it to West marine. If it does or does not post your results back on this thread. may help a fellow boater.
http://www.westmarine.com/buy/telefl...able--11886934 they also sell one w a 4' cable i just didnt find it doing a quick search and is priced about $30 less |
| All times are GMT -5. The time now is 05:31 AM. |
