-   Wanted (https://www.offshoreonly.com/forums/wanted-244/)
-   -   Wire harness for 454/502 carb (https://www.offshoreonly.com/forums/wanted/350724-wire-harness-454-502-carb.html)
niteridder64 11-08-2017 01:52 AM
I am looking for a good cond engine wire harness for a carbed 502 w/ the alternator on the starboard side. My eng has a single serpentine belt.
Sick Stinger 11-08-2017 07:55 AM
I should have one
Jat64 11-08-2017 04:24 PM
I am parting out a Baja and have one
niteridder64 11-09-2017 05:46 PM
Still looking for a wire harness, anybody, starboard side alternator.
niteridder64 11-17-2017 12:13 PM
Last shout out for a wire harness w/ alt on starboard side before I cannibalize my mpi harness. Also looking for a hose- circ pump to tstat 32-861183
Crude Intentions 11-17-2017 06:36 PM
I used these. Made my own custom harnesses. It's the same one merc used. All colors are the same. You only have to add a couple wires involving alternator, starter, relay and 50 amp breaker.
https://bpi.ebasicpower.com/shop/ind...aaf29bf176ccb4
niteridder64 11-17-2017 11:09 PM
Definitely another avenue, but I will be into it for $200 by the time I buy the breaker and relay. I'll just separate my mpi harness. Thanks for the suggestion.
Crude Intentions 11-18-2017 06:15 AM
You should have the relay and breaker on your mpi stuff. If not they aren't real expensive. Depending on age if the harness you can't see the corrosion down through all the wires. I debated re using but didn't wanna risk electrical gremlins. Lol. Good luck either way.
niteridder64 11-18-2017 10:32 AM
Harness is in good shape, no corrosion. If I rob the parts off it then I can't sell as complete harness so I may as well use it.
