Bravo One Upper/Lower studs
Anyone have some studs that connect the upper and lower units together laying around? I'm going to remove my 1" drive spacers and do not know where they might have been put for "safe keeping". Need 2 sets for twins. I have 2 drives laying around and just don't want to remove them if not necessary.
Let me know what you have, Thanks, |
I'm sure Sick Stinger has some laying around. You will need shorter upper to lower shaft couplers as well.
I should have 30 or so, believe I have some NIP also |
Have shaft couplers also |
Dang,I forgot the couplers were with them. I will look a little harder. I'll let you know what I find or can't find.
Thanks |
Sounds good, I can get them sent as soon as you know. |
1 inch studs and coupler
Any of you guys have a set of studs and coupler to fit a 1 inch bravo spacer or even a complete 1 inch spacer ?
| All times are GMT -5. The time now is 02:10 AM. |
