-   Wanted (https://www.offshoreonly.com/forums/wanted-244/)
-   -   Gen VI 454 oil lines , filter adapter (https://www.offshoreonly.com/forums/wanted/375870-gen-vi-454-oil-lines-filter-adapter.html)
tooslow 05-27-2022 07:41 PM
I am putting together a Gen Vi 454 . I have an extra set of mark iv accessories to use . I also have the seawater pump/ fuel pump . From my reading I think I need the piece that mounts to the filter pad on the block and some hoses ? I would also need a cooler. Im learning as I go , im not 100% sure what I even need . Thanks in advance
smokediver 05-29-2022 08:54 PM
I would source aftermarket.. the lines and fittings on stock are barely adequate.. depending on your horsepower you can size your cooler accordingly
tooslow 05-30-2022 12:46 PM
Yes , the more I read about it I agree with what you are saying .
GLENAMY 242SS 05-30-2022 01:40 PM
Hardin Marine is your friend. Use Summitt Racing for the lines and fittings.
Stephen Ramage 06-01-2022 12:42 AM
Oil lines
I have everything you asked for from a gen 6 454 mpl I can send you pics if you still need
tooslow 06-01-2022 06:44 PM
PM sent
