Need a 500 efi camshaft
Looking for a 500 efi camshaft or a 168731 I believe is the same
the 731 cam is smaller than the efi cam,,efi cam is 230/236,731 is 226/234
sutphen is correct - and I do have a spare one that came out of a low hour Merc 500EFI.
I would sell it for $325 shipped. You must use a melonized distributor gear. Crane 731 / 139011 retrofit Hyd. Roller 288/296 @ .004 226/234 @ .050 .587 / .610 in/ex lift 112 LSA 5600rpm 500 EFI & 700 SCI Merc engine Crane 139771 Hyd. Roller 169621 HR-292-2S-14 IG 292/298 @ .004 230/236 @ .050 .598 / .610 in/ex lift 114 LSA 5800 rpm |
[QUOTE=SFOcean;4885614]sutphen is correct - and I do have a spare one that came out of a low hour Merc 500EFI.
I would sell it for $325 shipped. You must use a melonized distributor gear. Crane 731 / 139011 retrofit Hyd. Roller 288/296 @ .004 226/234 @ .050 .587 / .610 in/ex lift 112 LSA 5600rpm 500 EFI & 700 SCI Merc engine Crane 139771 Hyd. Roller 169621 HR-292-2S-14 IG 292/298 @ .004 230/236 @ .050 .598 / .610 in/ex lift |
Originally Posted by SFOcean
(Post 4885614)
I would sell it for $325 shipped. You must use a melonized distributor gear. 500 EFI & 700 SCI Merc engine Crane 139771 Hyd. Roller 169621 HR-292-2S-14 IG |
Originally Posted by SB
(Post 4885649)
IG stands for iron gear on the cam .
Originally Posted by mtnrider
(Post 4885653)
so what distributor gear should I use
Teague also has new ones made by a different manufacturer |
still looking for one more camshaft.
Have one like new low hours 350.00
Ron Sporl 504-616-6005 |
| All times are GMT -5. The time now is 03:37 PM. |
