-   Warlock (https://www.offshoreonly.com/forums/warlock-66/)
-   -   Speed (https://www.offshoreonly.com/forums/warlock/20066-speed.html)
two-air 03-13-2002 07:25 PM
Speed
I have a 1999 Warlock 29 with an HP-500 (Carb) with 100 hours on it, a 28" pitch bravo one prop. At full throttle I am turning 4800 RPMs. The best I can get out of it is 72.5mph. (1/3 tank of gas). Does anyone have any ideas on how to tweak my top end up a bit... I love the boat it is so awesome in rough water, I just would like a little more speed!!!!!!!!!!!!!!!
Bruce 03-14-2002 10:33 AM
Is the propeller stock from Mercury, or lab finished. The easiest way to get more top speed would be to lab finish the propeller.
DanB 03-15-2002 06:55 PM
I had my 28p labbed and cut down to 14 1/2" and picked up about 2mph on my 27 Warlock. I did calculate that I got more slip tho. The big improvement was in the handleing. Got rid of alot of the chine walk and torqueing over. I've since added about 150 hp and am able to spin a 30p labbed. Picked up about 5mph over the 28 in the mid range. Your welcome to try my 28 if you feel like towing down here. (FT Myers)I'll probably come up to the Sarasota races if you want to wait till then. You may want to try a 26p non labbed in the meantime. You should pick up the rpms and speed some. Most 29's with a 500 seem to run best with that setup. Stay away from the Hydromotives..they just dont seem to work on a Warlock. Me and several friends have tried them.
Ive been told dropping the X dim a tad helps some too. I want to find out more about that tho before I try it.
When did you get your Warlock?
Dan
racefever 03-15-2002 07:43 PM
need more air!!!!!! blueprint bottom !!!! these boats have hooks in bottom and are starving for air. I'll be glad to talk to you. e-mail me with your number. i have 2 29 warlocks. lots of little tricks.: lab prop 28 work best for us.
