slightly overheating 502
One of the things I noticed when running the boat in Lake Tahoe in Dec (52 degrees out with cold water) was that one motor ran at 170 degrees and the other at 185 degrees. I asked the previous owner if this would be a guage, a impeller or a thermostat. He said he put a heat gun on both engines and they read the same temp.... He did not know. I suspect I need to do this myself again to see if this is an accurate reading. This boat has huge sea strainers and the amount of water passing through both looks the same.... Plus the water pressure guages both seemed about the same. Possibly the thermostat? Just what type and temp thermostate is put in these boat motors? A regular 160 degree or are marine thermostats different? Just what is considered overheating? I have seen complaints about 200 degrees on other boats.......... Is 185 high?
Your gauges could be off but either way that is good temps. 240 probs. 180ish all good. Enjoy the boat and dont sweat it until you see them erratic
I chased a similar problem once checked everything even the water hose at the transom found nothing.Turned out my gauges were 10 degrees hotter than the motor.I took readings with a temp gun right were the temp sender was and it was 10 degrees lower than the gauges.
Mine would also do it more when it was cold out I felt that the thermostats were not opening as fast as they should so I put 140 degree thermostats in. |
Originally Posted by Expensive Date
(Post 3282883)
Originally Posted by Poker~N~Run
(Post 3282859)
