Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-23-2009, 06:33 PM   #1
01' Baja 272
Holeshot - single v. twins?
Just wondering what the difference would be getting on plane between my 272 and say a 30 or 33 Outlaw?
My 272 w/496, tabs 1/2 way down, drive all the way in, yanks the arms out of their sockets pulling up a skier. I usually don't even use the tabs to get on plane. Just drive all the way in taking off. Would the same be true with a twin powered boat??
Thanks!!
mb.
motoboy is offline   Reply With Quote
Old 09-23-2009, 07:06 PM   #2
redbud35's Avatar
272 faster out of the hole than the 30.
redbud35 is offline   Reply With Quote
Sponsored Links
Old 09-24-2009, 12:00 PM   #3
Got Boost ???
Smitty's Avatar
2000 Baja 36 Outlaw
What pitch prop are you running??
Sounds like you are propped to pull skiers/toys and not for top speed.
If both boats are pitched for top speed, then the twin engine boat will win.
Smitty is offline   Reply With Quote
Old 09-24-2009, 12:13 PM   #4
01' Baja 272
Quote:
stock 23p
does 60-62 on GPS @ 4900rpms
Considering moving up to a bigger boat and wonder what I'd be sacrificing. Holeshot was the first ot come to mind.
thanks for the replies
mb.
Old 09-24-2009, 12:23 PM   #5
personnaly boatless ...
jeff32's Avatar
personnaly boatless for now...
I'd say the twin would pull... 5 skiers! way better with twins for hole shot !
jeff32 is offline   Reply With Quote
Old 09-24-2009, 12:26 PM   #6
JaayTeee's Avatar
2002 baja 33 o/l 575sci's
Another thing that comes into play is drive
height.
If they're fairly high, it's pretty easy to
blow them out when coming out of the hole
if you hit it too hard.
Usually, the manufacturer, on twin engine
boats, doesnt put too much emphasis on
how they come out of the hole, they're
looking at how they work at cruise speed and
up top.
And on a side note, bravo drives just "love"
full throttle starts on big, heavy boats
JaayTeee is offline   Reply With Quote
Old 09-24-2009, 01:59 PM   #7
Charter Member #34
Dock Holiday's Avatar
Quote:
Originally Posted by JaayTeee View Post
And on a side note, bravo drives just "love" full throttle starts on big, heavy boats
Yeah there has never been a failure from that!
I see no reason at all to have a fast / quick hole shot on a big twin engine boat. Actually it is more fun to me anyway to take off very slow and easy and come up behind the smaller / slower boats than to hop out front. That will also get you the most life out of your drives.
When you get over about 25 foot length on a single or any twin you are putting a lot of stress on the drives and related components doing a hole shot.
I have been on two fountains that were so over proped with high "X" dimensions that planning felt like it took minutes instead of seconds and many times they would blow out and you had to start all over again. But hey we went two miles per hour faster on top end!
The advantages of twins in a larger hull far exceed everything else that I would not be worried about planning time.
Just my 2 cents worth
Happy boating
Dock Holiday is offline   Reply With Quote
Old 09-24-2009, 02:32 PM   #8
socalstone's Avatar
Seems to me in the off-shore/performance boat world there is no such thing as hole shot!
The concept doesn't even exist in the boating world unless you are talking: towboats, small 15-21 ft performance boats, or PWCs. I have a 26' single and enjoy taking off gently and easing onto plane as well. Besides, there is plenty of time to abuse the drives on the top end!
socalstone is offline   Reply With Quote
Old 09-24-2009, 03:49 PM   #9
oklaoutlaw
Quinlan's Avatar
02 38 T/S GUN 43 Wellcraft Portifino
I pulled a salom skier w my 29. ONCE! Bout drowned him but he got up! Wakeboarders NO problem.
Also he ownes the boat now
Quinlan is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
