Crazy trailer.
Received 3,020 Likes
I actually wished I had them on my South Florida trailer because it was so narrow it was a PITA to load. Stressed me out every time!
Tank, I remember a lot of weird details.
I can say there are times when I can appreciate a setup like that.
My Aluminum Myco does not float, but Activeshack's does in salt water. (My Aluminum Rocket trailer floated. It's a royal PITA even with guide poles.) That would be one setup that would add some weight and help with the trailer trying to float away to the side.
Last season, I came up the ramp after retrieving, and my boat was up on a chine, off by about 1.5 inches. I went to back it down the ramp again so it could float over; and the heavily corrugated ramp vibrated the boat/trailer enough that it danced the boat down into position. Unfortunately, as the weight of the boat on the edge of the chine "de-crested" the side of one of the flat 2x6 bunks; it splintered off the edge of the board, and one of the mounting bolts took a gouge out of the gelcoat on the edge of the chine. You want to talk about pissed? BIG TIME!
And I know we never plan to do it, but it happens...
How about loading a twin engine boat with only one engine/drive? You want to talk about a PITA? That's a pretty fool proof setup right there.
Those might look funny but I can see the function in them. The local boat ramps around my area seem to really drop off after the concrete, and if you are over 30ft in length the trailer is so far below the surface the boat walks all over until you are half way out of the water. I have had to back in the water up to 4 or 5 times to get it straight. The last time at the ramp the place was empty, and I needed one more "backing in" to get it straight on the trailer and of course all the ramps were empty but the one boat coming in pulled into my ramp. Needless to say my patience was gone especially when I noticed it was the owner of an "offshore boat" company in the Algonac area. Maybe I'm just to lazy to modify my trailer like that but a little courtesy at the ramp is nice.
By the way...The boat doesn't look half bad for 45k.
Yea, I've done all of that as well. Loading with one motor with my skinny trailer was no walk in the park. I also took a chunk out of a chine when my boat went on wrong....I hear you 100%. There were many times I wished I had guides. The Baja was easy, just slap it in and hook it up! The rails did all the work.
Nice pucker factor let me tell ya!
