How to's needed
Could be the gasket to the neck piece that the hose connects to.
Part #21 in the diagram.
http://www.perfprotech.com/store/ass....aspx#assembly
Actually, Its leaking down onto the neck (20,in the diag) seems like it would have to be coming from above that point to do that. I had to go out of town this past weekend so didnt get a chance to check it again, but will do that this week .
Its more than likely the seal on the upper swivel shaft. If you changed the bellows you can change this. It takes a little time the first time but once you have done it it gets easier each time after that
Its #5 on the link above.
