rebuilding 454
#71
Buddy1234 -
Didn't you beat me racing once - Bench Racing .
On a serious note, with your big block what you need to wake up that boat is a set of bleed up lifters, adjustable roller valves, peanut butter port heads (I run'm - see info under my name to left),Harley two pump carb, corvette heads, and an external cam pulley. To start with.
As you mentioned, going to a bigger outdrive always provides more speed - my experience is 10mph or faster.
The external cam pulleys really wake it up. I have the small pulleys on mine. The cam spools up faster that way.
#73
7500 rpm. you didn't change tach. it is reading 33% high. also you are running 1.65 or 1.68 gears in the v6 drive so engine IS over revving, but not that much. oh, if you have 188 heads, the 454 is a 365 hp mag motor, not 330 hp standard motor. much better engine to start with. what I was saying about the raven hull, is, spend what you like in time-energy on motor-drive, the boat will go fast and look good. I woulda bought it for 500 in a heartbeat if it fell in my lap. but be on lookout for a better hull to repower with that package in the future. you obviously know how to buy right. a 22 velocity, a Baja hammer, any 24-7 hull. and not even talking resale value, boats aren't worth the cost of building anymore. just a hull that will hold up to the pounding a boat gets when driven hard. good luck.
#76
Found his brother in this old thread
http://www.offshoreonly.com/forums/g...ce-please.html
sotofast5U
sotofast5U
#78
You stupid fackz that try and build big motorz to have fun just need one of these
http://www.seaboundsupply.com/davis-...FYN0Ogod4g0ABg
Hole shots like a mustang b!tch!!!
#80
sotofast5U
sotofast5U
