rebuilding 454
Old 03-06-2014 | 02:37 PM
  #71
Knot 4 Me's Avatar
Originally Posted by SB
Buddy1234 -
Didn't you beat me racing once - Bench Racing .
On a serious note, with your big block what you need to wake up that boat is a set of bleed up lifters, adjustable roller valves, peanut butter port heads (I run'm - see info under my name to left),Harley two pump carb, corvette heads, and an external cam pulley. To start with.
As you mentioned, going to a bigger outdrive always provides more speed - my experience is 10mph or faster.
It's all Bravo II's these days and lap-Finnish elephant ear aluminum props.
Knot 4 Me is offline
Old 03-06-2014 | 05:57 PM
  #72
Don't forget the threw haul exzaughts !
4bus is offline
Old 03-06-2014 | 07:40 PM
  #73
Buddy1234 -
Couldnt agree more on the peanut butter ports, especially at 7500RPM.
The external cam pulleys really wake it up. I have the small pulleys on mine. The cam spools up faster that way.
MILD THUNDER is offline
Old 03-06-2014 | 08:16 PM
  #74
well i put on a bigger outdrive and i only picked up 7 mph.iffen i can finder il put r up da viv.
mike tkach is offline
Old 03-07-2014 | 04:52 AM
  #75
7500 rpm. you didn't change tach. it is reading 33% high. also you are running 1.65 or 1.68 gears in the v6 drive so engine IS over revving, but not that much. oh, if you have 188 heads, the 454 is a 365 hp mag motor, not 330 hp standard motor. much better engine to start with. what I was saying about the raven hull, is, spend what you like in time-energy on motor-drive, the boat will go fast and look good. I woulda bought it for 500 in a heartbeat if it fell in my lap. but be on lookout for a better hull to repower with that package in the future. you obviously know how to buy right. a 22 velocity, a Baja hammer, any 24-7 hull. and not even talking resale value, boats aren't worth the cost of building anymore. just a hull that will hold up to the pounding a boat gets when driven hard. good luck.
dereknkathy is offline
Old 03-08-2014 | 07:02 AM
  #76
This thread reminds me of a "cummings" forum thread. How do I install a smoke switch to oral coalle?
ham_r_down01 is offline
Old 03-08-2014 | 12:53 PM
  #77
Found his brother in this old thread
http://www.offshoreonly.com/forums/g...ce-please.html
sotofast5U
4bus is offline
Old 03-08-2014 | 04:42 PM
  #78
sotofast5U
yep,a real head case with a shetty attitude.
Old 03-08-2014 | 06:20 PM
  #79
Damn skippy! Peanut butter port heads will rev you right on up o 7,500 in a Jif !!!!
tpabayflyer is offline
Old 03-08-2014 | 06:40 PM
  #80
You stupid fackz that try and build big motorz to have fun just need one of these
http://www.seaboundsupply.com/davis-...FYN0Ogod4g0ABg
Hole shots like a mustang b!tch!!!
Unlimited jd is offline
