Go with H series or P series bearings?
Mainly the chamfer for the radius filet. The "H" bearing, and "P" bearing are the same widths as far as I know, but the "H" bearing has a chamfer, the "P" does not.
A stock cast crank may not have much of a radius on the journal, and a "P" would be sufficient. Aftermarket high performance forged cranks, have filet's that require a chamfered bearing.
http://www.fme-cat.com/Docs/1102.pdf
[ATTACH=CONFIG]542463[/ATTACH][ATTACH=CONFIG]542462[/ATTACH]
