Go Back   Offshoreonly.com > Technical > Drives and Lower Units
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-09-2009, 10:55 PM   #41
29 Fountain
Quote:
Originally Posted by Strip Poker 388 View Post
Im interested in a 5gall pail, I guess they would drop ship from the closest warehouse to me?
PM Sent
Racerngr1 is offline   Reply With Quote
Old 06-12-2009, 08:14 AM   #42
Dino's Avatar
Quote:
Originally Posted by John the Drive Man View Post
Because it's not made for longevity, like the Hi Performance green oil is. It should be changed every 50-60 hours.
Whats the actual weight of the merc hp oil??
(Eleven) Neil-Built Cigarettes
Dino is offline   Reply With Quote
Sponsored Links
Old 06-22-2009, 08:19 AM   #43
RaggedEdge's Avatar
'06 35 Lightning Merc HP 525's aka The Black Biotch
Quote:
Originally Posted by CB-BLR View Post
I like this stuff better than the Amsoil I used to use.
http://aerospacelubricants.thomasnet...-21?&forward=1
Picked up almost 100 rpm in back to back testing.
Chris
Which weight are you using, the 75/90 ?
vs which weight in the Amsoil ?
Low Tech and Proud Of It
RaggedEdge is offline   Reply With Quote
Old 06-22-2009, 12:15 PM   #44
Chris
CB-BLR's Avatar
2009 Nordic Heat - 600sci - Whipple Stage X - SCX drive
Straight 80 weight.
The Amsoil is 75/90 Severe Gear.
I will be testing the Alisyn 75/90 next oil change.
Chris
CB-BLR is offline   Reply With Quote
Old 06-23-2009, 01:38 AM   #45
29 Fountain
I would recommend using the marine gear lube instead of the Severe gear because it was designed to work better with the cone clutches in the bravo and also with up to 10% water contamination. Let me know if I can help.
Old 06-27-2009, 09:37 AM   #46
RaggedEdge's Avatar
Quote:
Just switched to the Amsoil. I called the Amsoil tech line and they said the marine, also said they sponsor a race boat that runs it in their drives, Teague I assume. Then called Teague and their comment was that the marine was fine for family craft, but only stock and use the severe gear in their drives. I got the severe gear based on their advise, actually is the 75-110. They said they did use the 75-90 but feel the 75-110 is a little better and now only stock it. Honestly think for my application the 75-90 would be fine but they seem pretty solid in their choice. Told me that the weight difference would not take away any rpm so we'll see.
Old 07-20-2009, 12:25 PM   #47
1997 fountain 35 lightning
Alisyn Pro Gear 21
Chris
I've used Alisyn from Aerospace Lubricants for years, by far the best. The engineers from Aerospace refer to Amsoil as "sludge". "I'm just sayin'"
smokinbob is offline   Reply With Quote
Old 07-21-2009, 08:25 PM   #48
29 Fountain
Quote:
When you look at the numbers, that Aerospace Lubricants isn't a bad product at all but when you compare the number to Amsoil saying that Amsoil is sludge, that's ignorant. The oil's are actually quite similar and priced quite a bit less.
Old 07-21-2009, 10:56 PM   #49
2007 Sunsation Dominator SS
That is exactly what I tried to say about 3 pages ago. Chemically the stuff looks good, but is it better, no, and especially not for the price!
07DominatorSS is offline   Reply With Quote
Old 07-30-2009, 01:11 AM   #50
AMSOIL!!!!!!!! Extreme Best
NordicSS is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
