Metal shavings on drain plug >
Old 04-06-2011, 01:04 AM
Received 1,826 Likes on 911 Posts
Originally Posted by Underdog88
I drained both of mine thru a paint strainer and got nothing. Fine stuff on drain plug mags. but one came nice clean and green and the other was black. I'm a bit worried too.
Mine are the same way. Left hand rotation drive is pretty dark.
Griff is offline
Old 04-06-2011, 07:46 AM
Underdog88's Avatar
Now that you say that, it was my left hand turning drive as well. Wonder if I should switch them while there off to "spread the wealth"?
Underdog88 is offline
Old 04-06-2011, 07:54 AM
CigDaze's Avatar
Interesting observations on darker oil in LH drives. Darker usually means hotter.
Now, it's common knowledge that Bravos can turn either way because they have symmetrical gear patterns but that necessarily doesn't mean that the oil is flowing properly turning opposite directions...could there be less cooling (foaming, etc.) when turning LH versus RH?
CigDaze is offline
Old 04-06-2011, 08:07 AM
Underdog88's Avatar
It's also the drive which I use the least. I spend much of my time running on one motor when not on plane. RH has the PS pump.
Old 04-06-2011, 09:11 AM
BDiggity's Avatar
Hey Scott, so this will probably be a dumb question but is the rotation based on looking at the drive from behind or from the front? It was my starboard drive that was darker, & i assumed i was turning the props out, but i will verify. The port drive was nice & green.
BDiggity is offline
Old 04-06-2011, 09:59 AM
Originally Posted by BDiggity
Could a bad bellow allow water in the bilge as well as the drive? Be nice if i could fix two issues at once.
I have never had a TRS drive, but on other drives a bad bellows can sink the whole boat. A leaking bellows is not something to be taken lightly
rexcramer1 is offline
Old 04-06-2011, 10:28 AM
Underdog88's Avatar
Looking at the props from the rear. LH is the one spinning counter clockwise.
Old 04-06-2011, 10:31 AM
BDiggity's Avatar
Thanks, thats how i was looking at things.
BDiggity is offline
